Remote Control Viewer › Viewer Pane › Viewer Properties Dialog › Configure Recording Options
You can enable or disable the default connection settings for the recording of remote control sessions and to select the location to save the recording.
- Right-click the Viewer node and select Properties.
- Select Record.
- (Optional) Specify whether recording begins at the start of each session. By default this option is not enabled.
Note: This behavior can be changed before establishing a session by adjusting the setting on the Viewer tab of the Connection Settings dialog.
- Specify the default path where you want to save the recorded sessions. If the path is left blank, the system-wide Temporary folder is used.
Note: This path can be overridden before establishing a session by adjusting the setting on the Viewer tab of the Connection Settings dialog.
- (Optional) Click Browse to access the Browse for Folder dialog, which lets you navigate the folder path for saving recorded sessions.
- Click OK.
Your recording options are saved.
More information:
Connection Settings Dialog
