The pifself command generates a self-installing PIF product using the PIF product file created by the pifmk command. The PIF product can be installed without using any installation program on the target computer. A standard shell invokes the installation procedure. Sufficient free disk space is required for the product generation; minimum size is the size of the product to be packaged.
The -a option lets you create a self-installing PIF product, even if the product was created for “Any” platform.
The -j option lets you integrate a Java Runtime Environment (JRE) in a self-installing PIF product. This JRE will then be used by the Installer on the target system to run the installation dialogs.
When you use the -s option, you can split the self-installing PIF product into three separate units, the start script, the actual PIF product, and a self-installing shell script including the Installer. To have these separated units is of value if you are working in a software delivery environment and do not need the self-installing function. In this case, you can register only the separated actual PIF product in the Software Package Library. Whenever you want to use the self-installing function, you must ensure that the three units mentioned previously are located in the same folder, and run the self-installing shell script.
pifself f PIFfile d selfinstallingfile
[a platform] [j {JREpath|"default"}] [s] [o]
Specifies the name of the PIF product file.
Specifies the file name of the self-installing PIF product.
Specifies the name of the operating system platform of the target computer where the PIF product shall be installed.
Imports the Java Runtime Environment (JRE) from the specified path or uses the default JRE. The default JRE is a stripped and downsized JRE version for Linux platforms. The value of JREpath should be a valid JRE directory like /usr/lib/jvm/jre-1.5sun.
Specifies separate. The PIF product file specified through the -f option is separated from the self-installing file.
Specifies overwrite. If an item with the same name already exists in the destination directory, it is overwritten.
Exit status:
Displays the status of the command execution. The value zero (0) means OK, any non-zero value indicates Error.
Example: Create a self-installing PIF product
The following command creates a self-installing PIF product using the file test-pif.AIX.@pif. The self-installing PIF product is stored as test-pif.AIX.sh.
pifself -f test-pif.AIX.@pif -d test-pif.AIX.sh
