Previous Topic: PropertiesNext Topic: pifproto - Create a Prototype File for a PIF Product
Packager and Installer Commands
You can use the following commands at the command line to create and register PIF products:
pifproto
Create a prototype file for a PIF product.
pifmk
Generate the PIF product file.
pifself
Generate a self-installing PIF product.
pifextract
Extract a PIF product file.
pifdelta
Create a delta PIF product.
piflib
Generate a PIF library file.
pifpatch
Generate a PIF patch product automatically.
sd_registerproduct
Register a PIF product in the Software Package Library.
You can use the following command to install PIF products and manage installed products on the target computer:
lsm
Install, remove, save, query, or list products.
