The prototype file is an ASCII file used to specify information about the PIF product. The information is bundled in sections, depending on the purpose and the contents of the information. A section can be omitted when it is not relevant for the PIF product. The prototype file can contain the following sections:
The prototype file is created using the pifproto command or by entering appropriate values through the Packager GUI. The name of the prototype file is created as follows:
prodname.platform.@prm
Following notation conventions apply to prototype files for PIF products:
#keyword: property1 , property2 , ... ;
Each keyword is lead by a hash sign (#), and terminated by a colon (:).
Each property is separated from the subsequent property by a space-comma-space sequence ( , ).
Properties shown in square brackets [ ] are optional and can be omitted. In lists of properties you must keep the separating space-comma-space sequences for compiler reasons, for example, if properties prop2, prop4, and prop5 are optional:
#keyw: prop1 , , prop3 , , , prop6 ;
