When you use the PIF SDK to create prototype files and PIF products, you must meet file naming conventions, as described following.
The file name of the prototype file is as follows:
prodname.platform.@prm
The file name of the PIF product is as follows:
prodname.platform.@pif
The file name of the prototype file for a language resource is as follows:
prodname.languageID.@prm
In this file name, languageID is a three-character language identifier, for example, ENU (English (U.S.), DEU (German), FRA (French).
The file name of the PIF product for a language resource is built as follows:
prodname.@languageID
In this file name, languageID is a three-character language identifier (for example, ENU (English (U.S.), DEU (German), FRA (French)).
The file name of the delta product (which contains the files that differ between a prior version and a resulting version of the same PIF product) is built as follows:
prodname.platform.priorversion-resultingversion.@pif
When you create a delta product from the Packager GUI, its file name is automatically generated in this format. We recommend following this file naming convention also when creating the delta product with the pifdelta command, although it is not mandatory.
