Previous Topic: Scripts within the Scope of Product Installation and RemovalNext Topic: Usage of Non-shell Scripts
Usage of Internal Procedures
Internal procedures are script files used to configure and interchange information with the product installation process. Internal procedures are part of the product; each of the script files must be defined in the file list of a component. Execute rights must have been specified for these script files.
You can create a new script file from the Packager GUI using the internal editor (which opens when you choose the Add New Files function.) Saving the new script file automatically adds its name to the file list of the component.
An existing script file is added to the file list of a component by using the Insert files function for the component of the PIF product.
If you want to add the internal procedure to a specific component, the procedure must be defined in that specific component (through the GUI or as an entry in the appropriate component section of the prototype file.) If you want to add the procedure to the product in general, the internal procedure can be defined for the product (through the GUI or as an entry in the product section in the prototype file.)
You can specify the following properties for internal procedures:
Execution Time
Execution time of the script. Possible values are as follows:
Options
If your script allows using command switches to configure the script execution, you can specify these switches when adding the internal procedure to the product. These command switches are applied to the script during script execution.
Interpreter
Optionally, you can specify an interpreter if the default interpreter, the shell, is not used.
