You can write scripts and executables for the Installer to run prior to or after the installation or removal of a PIF product on the target computer.
By default, Bourne-compatible shell scripts are assumed for execution. You can run internal procedures as well as nonstandard shell scripts executed by another interpreter, and you can use parameters to customize and control the scripts.
