When you create a PIF product using one of the standard templates, except unattended.Any.@enu, the Packager automatically adds a set of standard installation dialogs to the PIF product.
On the Packager GUI, these dialogs are listed on the Dialogs tab in the subproject pane. In the prototype file, each of these installation dialogs is described in an individual Dialog section.
The standard installation dialogs contain a number of preset dialog elements which can be changed, enhanced, or copied using the Packager’s installation dialog editor.
