Previous Topic: Pre-install ComponentsNext Topic: Files, Directories, and Symbolic Links in PIF Products
Optional Components
For all types of components you can, if appropriate, specify that the component should not be installed with the product in any case, but only on demand (that is, by selecting this component from an installation dialog or depending on a parameter value in a response file.) Components that are installed only on demand are called optional components. For example, a set of documentation can be defined as an optional component.
Optional components can be selected or unselected with the use of a PIF parameter. If the PIF parameter is set to 1, the component is installed; however, if it is set to 0, the component is not installed. This parameter is assigned to the PIF package through the GUI with “components/advanced/installation behavior” or manually with the keyword “#cinstall:”. You can add a check box to provide the parameter with the according value. You must add this check box to a dialog.
