Previous Topic: Language-Specific ComponentsNext Topic: Optional Components
Pre-install Components
Preinstall components contain all files used prior to the actual installation of the PIF product, that is, before installation dialogs and scripts are executed. The preinstall components are extracted to a temporary folder, specified through the parameter PIF_PREINSTALL_DIR.
Typically, preinstall components contain items such as the following:
You may have several pre-install components with the same name, but different languages.
If the locale of the preinstall component does not match the system locale, an external language-specific PIF product will be used instead, if you have provided such a product.
