A text field is the standard input field for installation dialogs. The text entered is assigned to a parameter, which is then passed through the install process and made available for scripts. The parameter must be defined as a property of the text field. You can specify a script that validates the text entered in the text field.
We do not recommend using a text field and a text area in the same line of an installation dialog.
