The installation directory field specifies the installation path for the PIF product or one of its components. When a Java installation dialog is being created, a browse button (...) to start a directory selection is automatically added. The text string entered in the installation directory field is assigned to a parameter, which is then passed through the install process. That is, a parameter has to be defined that stores the directory. The parameter must match the product installation directory parameter or the component installation directory parameter. You can specify a script that validates the content of the input field.
