Previous Topic: HostUUID Must Be Removed on ImageX and Ghost (16-bit and 32-bit) ImagesNext Topic: OS Installation Parameter OSUser Must Not Be "administrator" or "guest"
Createbtimages: Floppies and eTrust
Symptom:
The command CreateBTImages does not work in my eTrust-protected environment.
Solution:
When you run the command CreateBTImages in an eTrust-protected environment, it is necessary to grant the command full access to the floppy disk.
