Symptom:
If the image contains the DSM Agent (not recommended!), the registry of an ImageX or a Ghost image contains the DSM HostUUID-key. Multiple systems installed from this image will get the same HostUUID. This will cause management problems.
Solution:
Remove the HostUUID key from the registry for any ImageX or Ghost image containing a Client Automation object that includes the Client Automation agent or the Data Transport Service agent.
The key to be removed is found in the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\ComputerAssociates\HostUUID.
