You must update the existing boot images with the new template files and any content updates published by Client Automation, so as to be completely compatible with the new release of Client Automation. The template files initialize the OS installation process on target computers. You can update the boot images either from the command line or using the wizard. You can choose to use the command line if you are updating multiple boot images using a batch script.
Note: If you have deployed the same boot or OS images on multiple boot servers, update the image and create a corresponding update SD package on the Image Prepare System first. You can then deploy the updated SD package to all the other boot servers in the domain using a software delivery job.
Important! Linux-Based Boot Image has been patched up to mitigate Shellshock vulnerability (Bash Code Injection Vulnerability). Updated Linux-Based Boot Image (Customized CentOS 6.3 x64 boot files) available on a DVD separate from the product DVD.
To update a boot image from the command line
CreateBTImages -i <image name> -e
CreateBTImages -i <image name> -c <winpepath> [-w <ospath>] -e
The command updates the existing image with the new template.
RegisterBTImages -i <image name> -s <manager> -e -b
The command updates boot image data in the MDB.
RegisterBTImages -i <image name> -s <manager> [-v <new version no>] -e -l
The command creates an SD package for the updated boot image and updates the boot image on the boot server. The updated package has "-update" appended to the original package name. You can stage the updated package on remote boot servers using an OS installation job.
The boot image is now updated and is registered with the domain manager along with the updated SD package.
To update a boot image using the wizard
The Update Boot Image wizard appears.
The boot image is updated and registered with the domain manager along with the updated SD package.
