Previous Topic: Support for IPv6Next Topic: Updating Customized Files
Upgrade Considerations
After you upgrade the OS Image Prepare System, domain manager, and boot servers, update the OS and boot images to use the latest image templates.
Important! When you perform an upgrade or apply a patch, the impacted OS image must be updated to be compatible with the new Client Automation release. When you update an existing OS image, ensure that the value of the changed boot parameter, if any, should have the new value after the Update OS Image wizard is completed. If not, change the value manually to new one supported by OS Image.
