Previous Topic: Security Management ReportsNext Topic: UNIX/Linux Reports
Access Violations Written to the Event Console Log
When a user attempts to access an asset to which he does not have permission, an error message is written to the Event Console Log. The Event Console Log may include violation errors that look similar to the following message:
CASF_E_465 Access violation by userid to asset ( mode ) assetname from source terminal_device at node source_node for access_type access mode. (context )
CASF_E_465
Specifies the general message number used for all DENY violations.
userid
Specifies the ID of the user who caused the violation.
mode
Specifies the user’s violation mode: W=Warn, M=Monitor, F=Fail.
assetname
Specifies the asset name of the asset involved in the violation. For WNT‑FILE, UNIX‑FILE, and UNIX‑SETID, the asset name is a fully qualified path name.
terminal_device
Specifies the device the user was logged into at the time of the violation.
source_node
Specifies the node from which the user logged into the system.
access_type
Specifies the access mode, abbreviated as follows: Rd=read, Wr=write, Up=update, Sc=scratch, Fe=fetch, Cr=create, Co=control, Se=search, Ex=execute.
context
Specifies the context of the violation. For Windows intercepted events, specifies the access type (read, write, and so on). For UNIX/Linux platforms, specifies the system call name. For CAISSF resources checks through components, the context specifies “resource.”
