This section contains the following topics:
How Security Management Is Implemented
Phase 1: Customize Security Management Options
Phase 2: Start Security in QUIET Mode
Phase 3: Create Rules for Production in WARN Mode
Phase 4: Set Options for Production, FAIL Mode
Security Management provides a policy‑based security system that protects against unauthorized access to vital CA NSM components and products.
To protect your management systems, you must augment physical security with software that can do the following:
Enhanced and simplified Security Management means reduced errors, greater responsiveness, and increased flexibility in meeting the needs of your organization. Most importantly, it means you can implement thorough and effective security policies without disrupting your work environment.
Note: The CA NSM Security Management components no longer provide file access authorization. If you need this type of additional security, you may want to evaluate eTrust Access Control. For more information, see Integration with eTrust Access Control.
Copyright © 2010 CA.
