Previous Topic: Security PoliciesNext Topic: How Security Management Is Implemented
How the Commit Process Works
The commit process puts that version of the policies you currently have defined into effect. It also generates the Decision Support Binary (DSB) files. Security Management requires that you execute the commit process during various phases of implementation. The commit process is typically required anytime after you make a change to your policies, that is, define, delete, or change a security access rule.
The commit process, when executed, performs the following tasks:
To perform a commit process, issue the secadmin command with option c from the cautil command line, or select File, Commit from the menu bar in the Security Management GUI.
Note: For command syntax, examples, and additional information about warnings and commit customization, see the secadmin command in the online CA Reference.
