The Explorer GUI toolbar buttons provide quick access to various functions of the Explorer GUI:
Opens a new Explorer GUI window using the current application plug-in.
Opens a new Explorer GUI window. Its root node is the node from where the selection of Explore From took place.
Returns to the previously selected node view.
Note: The drop-down list for Back and Forward icons displays a maximum of eight available nodes. The Back list comprises the last viewed nodes in the tree. The Forward list is empty until you have selected Back. The list grows for each selection of the Back button.
Moves you forward to the next node view.
Moves your selection one level up in the hierarchy.
Refreshes the currently selected node and its subtree.
Adds bookmark for the current node in the Explorer GUI application plug-in.
Creates a new node in the Explorer GUI. The command is active only if the currently selected node supports the command.
Displays the properties of the current node.
Deletes the existing node. The Confirm Delete dialog appears.
Toggles the display of the left pane.
Toggles the display of the History view in the left pane.
Toggles the display of the Bookmarks view in the left pane.
Toggles the display of the Search pane in the left pane.
Cuts the selected node.
Copies the selected node.
Pastes a copy of the clipboard contents in the insertion node.
Displays a list of available views:
Displays the online help for the selected application.
