Explorer GUI › Right Pane View › Choose Column Details
Use the Choose Columns dialog to control which columns display in the right pane view and to specify their sort order.
Note: If multiple users are defined to this computer, each user will have the rearranged column settings, specific for each selected node type, saved in a personal user registry.
To choose column details
- From the list of column names, select one or more columns to display.
The selected column names are marked with a checkmark.
- Arrange the sort order of the columns using the Move Up and Move Down buttons, which move the selected name up and down the list, respectively, one level at a time.
The columns are arranged in the specified sort order.
- (Optional) Adjust the width of each selected column by entering a pixel value in the Width of Selected Column(s) field.
- (Optional) Click the Show or Hide button to change the visibility of a previously selected column.
- Click OK.
The modifications are saved and take effect.
