You can delete a bookmark from the Explorer's Bookmarks list view.
To delete a bookmark
The bookmarks are listed in the left pane.
Alternatively, select the bookmark and click Delete in the File menu.
The Confirm Delete dialog appears.
Note: This dialog does not display if you have cleared the Confirm on Delete check box in the Explorer GUI Options dialog.
The bookmark is removed from the Bookmarks list view.
