The following table includes the OSIM job error codes, error codes description, and possible solution:
Error Code |
Error Description |
Suggested Solution |
0 |
Success |
Not Applicable |
1 |
The resource file for the OsimMove program could not be opened. |
This is probably an installation problem. Check the installation and start the operation again. |
2 |
Missing or invalid command line arguments. |
This is probably an error in the calling program. Contact CA Technical Support. |
3 |
The session with the OSIM Manager could not be established. |
This seems to be a temporary problem. Try again later. |
4 |
Unknown command specified on command line. Only “export” and “import” commands are supported. |
5 |
Job data output file not specified or the file could not be created. |
This might be a temporary problem (disk full). Try again later. |
6 |
Job data input file not specified or the file could not be loaded. |
The job data file does not exist or is corrupted. This might be a temporary problem. Try again later. |
7 |
A specified computer name or UUID was not found in the database (export operation). |
This could be a temporary database problem. Try again later. |
8 |
The specified name or UUID list file could not be opened. |
9 |
A computer was specified by name for export, but its host UUID is unknown. |
12 |
The file compress component could not be initialized or there was an error compressing or uncompressing the job file. |
This could be an installation problem. If the error occurs on import, the job data file might be corrupt. Check the compress component and then retry the operation. |
13 |
The result file could not be created or opened. |
This could be a temporary problem (disk full). Try again later. |
45 |
Movement of the OSIM job records not supported by the previous domain manager. |
Upgrade the previous domain manager from where the movement of OSIM jobs is attempted. |
107 |
207 |
A specified computer name or UUID was not found in the database (import operation). |
The specified computer is not registered with the new domain manager. Register the computer and retry. |
211 |
The required OS image for a job was not found in the database. |
A required OS image is not registered in the new domain manager. Register the OS image in the new domain manager with the same name as it was in the previous domain manager. |
214 |
A specified host UUID was not found in the job data file. |
