To move the OSIM job information during a computer move operation, configure the OSIM move configuration policies. Using these policies, you can control the overall behavior of transferring the OSIM job information from a previous domain manager to a current domain manager. You must apply these policies on the domain manager to which the agents are being moved. The values of these policies on the previous domain manager do not influence the behavior of moving the OSIM job information to the current domain manager. Thus, the OSIM move policies applied on the current domain manager define the transfer behavior of the OSIM job information, and not the policies applied on the previous domain manager.
To configure the OSIM move configuration policies
A list of configuration policies appears.
Specifies whether to move the OSIM job information along with the installation records from a previous domain manager during an SD computer move operation. You can set the parameter value to True or False. Setting the parameter value to True always attempts to move the OSIM job information and the installation records from the previous domain manager. However, setting the value to False disables transfer of the OSIM job information, and attempts to move only the installation records.
Default: True
Specifies whether to move the installation records from a previous domain manager after initiating transfer of the OSIM job information. If transfer of the OSIM job information fails with an error code that is present in the error codes list specified for this setting, the transfer of the OSIM job information and the installation records is postponed until the next computer move attempt is made. However, if the transfer of the OSIM job information succeeds or fails with an error code not included in the list specified for this setting, the process of moving the installation records is initiated.
Note: The error codes list is a comma-separated list and can include the following error codes:
1,2,3,4,5,6,8,9,12,13,45,107,207,211,214.
Default: 1,2,3,4,5,6,8,12,13,45,211
The OSIM move configuration policies are configured.
