Communication Policy Group
The Communication policy group governs CA-SD communication protocols for Unicenter Software Delivery extended and legacy agents.
The Communication policy group contains the following policies:
Specifies the port for the server to listen for legacy Unicenter Software Delivery agent connection requests.
Default: 4721
Specifies the size of file transfer blocks in kilobytes (KB). If you are running on fast networks, increasing the size generally improves performance.
Limits: 4–32
Default: 4
Indicates the maximum number of network connections allowed to and from this computer.
Default: 550
Indicates the maximum number of allowed network application peers for this computer.
Default: 200
Specifies the common system receive timeout interval in seconds.
Note: If -1 is specified, the timeout is indefinite.
Default: -1
Specifies the port number of the trigger process (TRIGGER).
Default: 4725
Specifies the wait timeout interval in seconds for connection confirmations.
Limits: 1–1000
Default: 120
Specifies the wait timeout interval in seconds for connection requests.
Limits: 1–1000
Default: 120
