The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Default Computer Policy (or User-Defined Policy) Node › Common Components Policy Group › CAF Policy Group › Scheduler Policy Group › Schedule the Mirror Synchronization
More Information:
Run the UAM agent Policy Group
Schedule the mirror synchronization to automatically synchronize the mirror with its parent repository at the scheduled time. The mirror repository is created when the synchronization job runs successfully for the first time after you have defined the mirror synchronization details.
- Navigate to Control Panel, Configuration Policy.
- Right-click the configuration policy that you applied on computers hosting mirrors and select Unseal.
- Navigate to DSM, Common Components, CAF, Scheduler, Run Mirrorsync from DSM Explorer.
- Select CAF Scheduler : Enabled and set the value to true.
- Configure the other parameters under the Run Mirrorsync node to specify the mirror synchronization schedule. For more information about the scheduling parameter, press F1.
- Seal and apply the policy on computers that host the mirror repositories.
The mirror synchronization is scheduled. At the scheduled time, the CAF Scheduler synchronizes the mirror with the parent repository.
