Previous Topic: Asset Collector Policy Group (Manager)Next Topic: Common Configuration Policy Group (Manager)
Asset Management Policy Group (Manager)
The Asset Management policy group lets you view or edit the following NIST SCAP support policies. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
SCAP Result File Location
Specifies the location of the storage folder for SCAP scanner result files. The default is to create a SCAP_Result_Files directory under the Client Automation install location.
