Power Management Calendar Policy Group
The Power Management Calendar policy group folder provides access to the Time Ranges configuration view for setting time ranges for the power management calendar. This policy group also contains the following policy:
Specifies the default value for the power management calendar when the current date or time does not match with any of the defined time ranges or when no time range is defined yet.
For example, consider a scenario where you set the Shutdown Behavior policy value to the calendar option 2 (controlled by calendar) immediately after installing the domain manager. But, you have not defined any time range yet or no time range matches the current date or time. In this case, the calendar returns the current time as Disabled for shutdown.
However, administrator can change the default value of the option to Enabled. This implies that when no time range is defined or when the current date or time does not match with the defined time ranges, the calendar always returns the current time as Enabled for shutdown.
Default: Disabled
