Compatibility Policy Group
The Compatibility policy group specifies backward compatibility support for pre-11.2 versions of DSM. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies that backward compatibility support for pre-11.2 versions of DSM be enabled, if set to True. Backward compatibility is necessary as long as there are any pre-11.2 partners with which to communicate. To enhance the encryption algorithms used for communication, set this policy to False when there are no pre-11.2 installations left in the whole DSM environment.
Default: True
