Wake-On-LAN Policy Group
The Wake-On-LAN policy group lets you set policies for remotely and automatically powering up physical computers in your enterprise. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
The Wake-On-LAN policy group contains the following policies:
Indicates the type of wake-on-LAN (WOL) datagram used to wake physical computers. Valid values are Unicast, Broadcast, and Broadcast + Unicast.
Default: Broadcast + Unicast
Indicates whether WOL datagrams can be sent to guest networks in addition to the original network where the computer is registered.
Default: False
If Enable guest nets is set to True, specifies the network address of each guest net. Up to five guest nets can be specified.
If Enable guest nets is set to True, specifies the subnet mask of each guest net. Up to five net masks can be specified.
Specifies the UDP port to which WOL datagrams are to be sent.
Default: 7
