Previous Topic: TCP Policy GroupNext Topic: Security Policy Group
UDP Policy Group
The UDP policy group contains the following User Datagram Protocol (UDP) policies. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Connection timeout
Specifies the timeout interval in seconds for connections.
Default: 10
Enabled
Indicates whether the UDP protocol is enabled.
Default: True
Port
Specifies the default UDP port. This is a real physical port. UDP is not supported by the port multiplexer.
Default: 3001
Send timeout
Specifies the timeout interval in seconds for send operations.
Default: 60
