Directories Policy Group (Software Management)
The Directories policy group contains the following policies for the names of important Software Management Installer directories. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the internal SxpWinComFilesDir parameter. This parameter is set to the specified value only if no other entry exists in the registry.
Default: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\CommonFilesDir, <locally managed>
Specifies the internal SxpWinProgDir parameter. This parameter is set to the specified value only if no other entry exists in the registry.
Default: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ProgramFilesDir, <locally managed>
Specifies the script directory. Scripts not distributed with the associated program can be placed in this directory.
Default: empty, <locally managed>
