Audit Policy Group
The Audit policy group contains the following DTS auditing policies. If the audit messages are empty, then the default audit message is enforced by the agent. The default message is dependent upon the locale where the agent has been installed; so, for example, if the German version of the agent has been installed, then the default audit message will be in German. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog. As with all policies, the values set here override the default values used by the agent, regardless of locale.
Indicates the message issued when auditing is started.
Default: ${DT} ${TT} DTS auditing started.
Indicates the message issued when auditing is terminated.
Default: ${DT} ${TT} DTS auditing stopped.
Indicates the message issued when a transfer that specifies this agent as the initiator or responder aborts.
Default: ${DT} ${TT} Transfer ${XD} from ${XF} to ${XT} aborted.
Indicates the message issued when a transfer that specifies this agent as the initiator or responder completes successfully.
Default: ${DT} ${TT} Transfer ${XD} from ${XF}::${XS} to ${XT}::{XK} completed.
Indicates the message issued when a transfer that specifies this agent as the initiator or responder fails.
Default: ${DT} ${TT} Transfer ${XD} from ${XF} to ${XT} failed; error message=${XX}.
Indicates the message issued when a transfer that specifies this agent as the initiator or responder resumes after having been suspended.
Default: ${DT} ${TT} Transfer ${XD}from ${XF}::${XS} to ${XT}::{XK} resumed.
Indicates the message issued when a transfer that specifies this agent as the initiator or responder starts.
Default: ${DT} ${TT} Transfer ${XD} from ${XF} to ${XT} started.
Indicates the message issued when a transfer that specifies this agent as the initiator or responder is suspended.
Default: ${DT} ${TT} Transfer ${XD} from ${XF} to ${XT} suspended.
Indicates the message issued when the Network Object Server fails during normal operation, not during startup. If the Network Object Server fails during startup, the default message, not the audit message, is displayed.
Default: empty
Indicates the message issued when the Network Object Server starts.
Default: empty
Indicates the message issued when the Network Object Server stops.
Default: empty
Indicates the message issued when the Schedule Object Server fails during normal operation, not during startup. If the Schedule Object Server fails during startup, the default message, not the audit message, is displayed.
Default: empty
Indicates the message issued when the Schedule Object Server starts.
Default: empty
Indicates the message issued when the Schedule Object Server stops.
Default: empty
Indicates the message issued when the Transfer Object Server fails during normal operation, not during startup. If the Transfer Object Server fails during startup, the default message, not the audit message, is displayed.
Default: empty
Indicates the message issued when the Transfer Object Server starts.
Default: empty
Indicates the message issued when the Transfer Object Server stops.
Default: empty
Indicates the message issued when a transfer aborts.
Default: empty
Indicates the message issued when a transfer completes successfully.
Default: empty
Indicates the message issued when a transfer fails.
Default: empty
Indicates the message issued when a transfer job aborts.
Default: empty
Indicates the message issued when a transfer job completes successfully.
Default: empty
Indicates the message issued when a transfer job fails.
Default: empty
Indicates the message issued when a transfer job resumes after having been suspended.
Default: empty
Indicates the message issued when a transfer job starts.
Default: empty
Indicates the message issued when a transfer job is suspended.
Default: empty
Indicates the message issued when a transfer resumes after having been suspended.
Default: empty
Indicates the message issued when a transfer starts.
Default: empty
Indicates the message issued when a transfer is suspended.
Default: empty
