Select a Policy
Use the Select Policy dialog to select a configuration policy to view or modify.
To select a policy
The list view displays all configuration policies defined to the enterprise, including the Default Computer Policy. It also displays the policy type, Sealed or Unsealed, and a description.
The relevant configuration view appears, displaying all policies specific to the selected configuration policy. If the selected policy is sealed, you can only view its settings, and the configuration view's fields and controls are disabled. If the policy is unsealed, all fields and controls are enabled, and the configuration view is ready to process policy modifications.
