The View Configuration dialog lets you view configuration job errors. To scroll through the list of errors, use the Previous and Next buttons.
The Errors Code field displays the appropriate system error code, and the Error Details field displays detailed information about the error, such as the conflicting policies and the relevant parameter.
Example: Policy 'XYZ' assigned to 'g2' conflicts with policy 'ABC' assigned to 'g2': parameter '/itrm/agent/cc/DeltaReportRetry'
