You can customize configuration settings to your specific requirements and combine them with default configurations. Use the Customize and Preview Settings dialog to view or modify the effective configuration settings for a computer.
To personalize the configuration settings
The Effective Settings dialog appears.
The Setting Properties dialog opens.
The new value is shown in the value column in the list view.
Note: To reset the value to the original value, click Use Effective.
The Setting Properties dialog closes and the new value is saved in the database. In addition, a Personalized Settings icon is added under Scheduled Policies.
