Select the installation state for the available features:
The features you can select, or omit, in this dialog depend very much on the software item, the .msi-file, that you started with and the procedure you selected.
In this dialog it is possible to specify the MSI featues to be installed and their state. This is helpful when only a part of a software package is to be installed and the software vendor does not supply a transform generator tool.
