The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Configuration Views Node › How to Use the ENC Authorization Rules Configuration View › Define a Realm
Define a Realm
Use the Realms tab page to define the realms in use within your ENC infrastructure.
To add a realm to the Realms table
- Enter the name of the realm in the Name field and click Add.
The realm is added to the Realms table.
- (Optional) Select a realm in the Realms table and click Remove to remove it from the list.
- (Optional) Add any relevant notes about the use or contents of the specified realm in the Note field.
- (Optional) Click Local to set this realm's configuration policies to Locally Managed.
- (Optional) Click Default to reset the realm's configuration policies to the original default values.
- Click Check to perform immediate validation of the data entered without committing the data.
- If cross-field or cross-table validation is successful, click Apply.
- Click the Name Mapping tab.
