To create a Software Staging Distribution Job
A Distribution Container is created containing software registration and software job orders.
Notes:
If you only want to distribute and stage the software to the domains you can omit selecting a scalability server.
On the last page in the wizard there is an option to distribute and register software packages at the domains. If you de-select this option, it is assumed the package is already available at the selected domains.
