Previous Topic: Modify Software PolicyNext Topic: Package Selection
Stage Software Package Wizard
The Stage Software Package wizard will guide you when you stage software packages on domains and on scalability servers attached to the enterprise.
The result is a software distribution which can be used to track the progress of the distribution to the domains.
The wizard has the following steps:
If you check the box "Open the advanced job settings dialog when the Finish button is pressed", you will be taken to the Setup Jobs dialog window.
