Configure the Logon Shield
Use the main dialog of the Logon Shield configuration view to configure the Logon Shield.
To configure the Logon Shield using the Logon Shield dialog
Indicates that the Logon Shield provider and -filter COM modules are unregistered on Windows Vista. On earlier versions of Windows, the sxpgina.dll file is uninstalled.
Indicates that Logon Shield is not activated when a software delivery job executes.
Specifies that the user be forced to log off when a software delivery job is waiting to be executed. The Logon Shield is activated during job execution.
Indicates that a software delivery job with a pre-defined condition is to be applied. When setting up a job, the administrator can select the Prevent user from being logged on when job executes option. When this mode of operation is selected, the user is forced off when there is a pending software delivery job, and the Logon Shield is activated during job execution.
Indicates that the user is not asked to log off when a software delivery job is pending. However, the job is only executed after the user has logged off. The Logon Shield is active during job execution.
Indicates that pending software delivery jobs are only executed when a user is logged on.
Note: This parameter only applies to Windows Vista.
The Windows Security options dialog appears.
Note: It is strongly recommended that this Windows policy be disabled when using the Logon Shield.
Note: It is strongly recommended that this Windows policy be enabled when using the Logon Shield.
You are returned to the Logon Shield dialog.
The Logon Shield is configured.
