Previous Topic: Record a SessionNext Topic: Stop Recording Sessions
Naming Convention for Recorded Files
Remote Control automatically assigns a name to a recorded session. The file name is comprised of the following elements: the name of the host computer name, the date, and time of the recording, followed by the .urc extension. The file name is represented in the following format: hostname_yyyymmdd_HHmm.urc.
Example:
If the viewer records a session on August 6, 2008 at 3:19 p.m., the file name is: hostname_20080806_1519.urc
Note: You can modify file names when you enable the recording or later in Windows Explorer, if you prefer another naming convention.
More information:
Open a Recorded Session
Record a Session
