Previous Topic: Recording Remote Control SessionsNext Topic: Naming Convention for Recorded Files
Record a Session
You can record an active session at any time.
  1. Click the My Sessions folder under the Viewer root node.
  2. Right-click the session in the My Sessions folder that you want to record and click Session Recording, Start.
  3. Change the file name or location, if necessary.
  4. Click Save.
    Remote Control begins recording the session and does not stop until you click Stop or terminate the session.
    Note: You can also select the Record Session option in the Viewer tab of the Connection Settings dialog. For more information about recording a session, see the Remote Control Viewer Help.
