The Query pane appears when you select a query from the Query folder.
This pane contains the following sections and fields:
Specifies one of the following tasks for the selected query:
Runs the query immediately. This task is the same as preview in the Query Designer.
Submits the query to a chosen engine. This query runs in accord with the engine schedule.
Opens the Enter Output File dialog, letting you export a query definition.
Opens the query in the Query Designer dialog, where you can modify the criteria of the query.
Shows the criteria the query is based on.
Displays the name of the saved result from the query. Double-clicking the result name lets you view the date and time the query was submitted to the engine. You can also delete the result file from the query.
Shows the status of the query. If the engine has processed the query, the date of execution is shown. If the engine has not processed the query, the field shows Pending.
Right-clicking a result set selects either of the available options:
Deletes the selected result set after delete confirmation
Renames the selected result set.
