You can append text to the text file when the policy is violated. The text is appended to a text file on the engine evaluating the policy. The text file is created if it does not exist.
The Configure Policy Actions dialog for this policy contains the following fields and check box:
Specifies the text file name. Click the Browse button (...) to open the Text Output Job dialog to select a text file. When the policy is violated, the specified text is added to the file.
Defines the text to be appended to the text file.
Specifies the macro that you want to add to the notification message. You can add any number of macros to the message.
Adds the selected macro to the message.
Evaluates the policy as defined during policy creation.
When you select this check box, the following happens when an asset no longer complies with the policy:
