You can add the asset that is violating the policy to the specified group.
The Configure Policy Actions dialog for this policy contains the following fields and check box:
Lists the existing group and lets you select the group to which the asset will be added to.
Removes the asset from the group when the asset complies with the policy.
Evaluates the policy as defined during policy creation.
When you select this check box, the following happens when an asset no longer complies with the policy:
