You can display messages on the violated computers.
Note: Creating policies with agent actions requires the agent to run twice before the action will be executed on the agent computer.
The Configure Policy Actions dialog for this policy contains the following fields and check box:
Note: Messages appear only on the Windows agent computers.
Defines the message that should appear on the violated computer.
Specifies the macro that you want to add to the notification message. You can add any number of macros to the message.
Adds the selected macro to the message.
Evaluates the policy as defined during policy creation.
When you select this check box, the following happens when an asset no longer complies with the policy:
