You can specify a notification message to be displayed on the violated assets.
The Add Notification Action dialog contains the following fields and check box:
Displays a list of user accounts that have previously been successfully authenticated with the DSM manager, for example, by logging into the DSM Explorer or DSM Web Console. Select the users who should receive this notification.
Note: Notifications are displayed only when a selected user is logged in. Otherwise, it is held up until the user logs in.
Describes the notification message.
Specifies the macro that you want to add to the notification message. You can add any number of macros to the message.
Adds the selected macro to the message.
Evaluates the policy as defined during policy creation.
When you select this check box, the following happens when an asset no longer complies with the policy:
