The Conditions tab lets you specify various conditions, for example, you can specify the date range within which you want the job or collect task to execute. This tab has the following fields:
Defines the first day the action is scheduled to take place.
Defines the last day the action is scheduled to take place.
Specifies the time before which the asset should not execute the action even if the agent is running.
Specifies the time after which the asset should not execute the action. However, an asset that has already started executing an action will complete.
Note: The syntax for Time is HH:MM:SS AM/PM
Runs the job only on the selected day(s). Checking this option enables you to select one or several days.
Lets you select one of the following, when selected:
Executes the action once daily.
Executes the action once weekly.
Executes the action once monthly.
Lets you select one of the following options, depending on your selection.
Note: Use the slider next to this field by dragging it left or right to adjust the value for the following options.
Executes the action after the selected time of the day or at the next possible time. If you select 15, action starts after 15:00 hours. If the computer is turned off before 15:00 hours, the action is executed during next startup, whenever that may be.
Range: 0 to 23 hours.
Executes the action after the scheduled day or at the next possible time, if the action could not be executed on the scheduled day. For example, if the action is scheduled to execute on Wednesday, but could not execute on that day (for example, user absent) it will execute the next time it is possible.
Range is Sunday to Saturday.
Executes an action on a specific day of the month, for example, the 10th.
Range is 0 to 30.
Note: All of the Time/Date Restrictions can be enabled and thus combined.
