You can exclude certain files or subfolders in the target directory from being removed or overwritten when the directories are synchronized.
Defines the name of the file or subdirectory that should be excluded. Specify only the file name and not the entire path. The asset management agent searches for the file in the main and subdirectories of the target directory.
Specifies whether the type is a File or Directory.
Updates the file name or type after either has been added to the list. Select the file or directory in the list and modify the details in the Name and/or Type field, and click Update.
Adds the name and type of the file or subdirectory to the list of excluded files.
Removes the selected file in the list.
